"No message found" & The folder '[Gmail]/All Mail on XXXXXX@gmail.com' could not be compacted because writing to folder failed. Verify that you have enough disk space, and that you have write privileges to the file system, then try again. bug1959858
Thunderbird has worked great for me for years, up until a few days ago. Currently running 137.0.2 and am encountering two problems. I have several emails and this has not been a problem in the past.
Now, I start TB and all works fine for minutes or an hour or two and then some inboxes start to display "No message found". If I close TB and restart it all is good, but noit for long.
The other issue which pops up is
"The folder '[Gmail]/All Mail on XXXXXX@gmail.com' could not be compacted because writing to folder failed. Verify that you have enough disk space, and that you have write privileges to the file system, then try again."
I have over 200GB free on the drive.
Thanks for any help solving this!
PS Win 10 Pro, so maybe time for me to upgrade to Win 11 which I plan to do in the few weeks anyway.
Modified
What you describe is https://bugzilla.mozilla.org/show_bug.cgi?id=1959858 but there is not yet a solution.
Thanks. Feel better knowing others see similar issue.
What version are you using currently? Would you consider using version 139, i.e. switch from esr 128? Do you still see the issue? Is this happening only on an empty folder, i.e. a folder which has no messages?
